MacBook Pro a1278 very Hot lower part
Hello,
I need help.
My macbook is very hot on lower part.
I opened this and replaced thermal past but this continue heating.
I have TG Pro installed and have this picture below.
Since you probably don’t have a Flir Cam available it will take a bit more patience, but after removing the bottom cover you’ll have to use your senses to try understand where the excess heat comes from..fingers are good at that unless you cross a scorching hot part..be careful and let us know where the heat comes from ? By the way..does Mac work fine despite overheating ?
这个答案有帮助吗?
Ok I go to do this.
Yes macbook working but I am afraid because the temperature too hot.
Now I trying Apple Hardware Test but this test stop on test logic board and not finish this test
Since is it kind of an older Mac, its the battery thats getting very hot. A new battery should help the situation. MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery
这个答案有帮助吗?
There are also cheaper batteries on amazon and ebay im sure but if you want a high quality battery I would go with the ifixit batteries. I've used them before and they're pretty good.
the hottest part is near the screen, where is the ventilation outlet, once when I opened the logic board was also hot
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 580
