跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1366 个问题 查看全部
Home button waterseal ripped off after screen replacement?
I did a screen replacement of my own and got kinda sloppy. Didn’t realize that there was a rubber around the home button and i accidentally ripped it off. Is there a way around this? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
It will work without it, but you break the water resistance in multiple areas. Don’t get the phone wet and it’ll be fine.
That said, I would replace the seal if at all possible or at least try and salvage the bad one. It’s still not going to seal right but 90% is still better then 0%.
这个答案有帮助吗?
得分 2
2条评论:
Do you happen to know where a replacement seal can be found? Thanks.
完成的
You probably need to buy a display or an unpaired button (for the seal). I'd live with it since opening the phone compromises the water resistance anyway.
完成的
添加一条评论
Don’t bother. You don’t know if the screen itself is waterproof because it could be assembled from parts by some other factories and did not apply glue all around the bezel.
这个答案有帮助吗?
得分 1
添加一条评论
Usually doing a screen replacement involves in ripping the water seal of your phone. Breaking the seal where the home button is should be no big deal. Just make sure to always keep in mind that your phone is no longer splash proof
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mikel Pimentel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 641
