跳转到主内容
Release date: Jan. 24, 2008; 8MP, 3x Optical Zoom, Built in optical image stabilizer system and Face Detection software; DIGIC III Image Processor.
13 个问题 查看全部
Suggested addition to repair instructions
When reassembling:
1) Be sure the ribbon cable from the LCD screen to the front of the camera is fully seated in the connector.
2) Before replacing the back cover, be sure the slide switch position is in the bottom position and so is the actuator on the back cover.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Gene, all of the guides are accessible to be changed by anyone. Just go to the guide you want to change and hit the "edit" link. Make the change you want and hit the "save". Later someone with a higher rating (and hopefully knowledge of the issue) will review you changes and approve or disapprove them. You get to be part of process and helping fix the world!
这个答案有帮助吗?
得分 5
添加一条评论
添加你的答案
Gene Arnold 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 10
总计 1,224
