跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
iPhone 7 Bluetooth not working
Ive been given an iPhone 7 to replace my old SE. Everything works as it should except for the bluetooth. When you go into settings, instead of the Bluetooth On/Off switch there’s just a spinning disc.
I’ve been through all the troubleshooters to the point of restoring it back to factory defaults with the latest IOS, but it still doesn’t work.
However I have noticed that when I put the serial number into Apples website, it should be a different color than it is (Apple say it is rose gold, but it’s actually silver) so I guess at some point it has been re-cased.
Everything else on the phone works fine including the 4G and wireless. Can anyone suggest what might be the issue with it?
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
All that I know of that could help is to reset or hard reset. I don’t know what to tell you other wise, that really sucks. If it still doesn’t work try contacting Apple’s Support team: https://support.apple.com/contact. Hope this works.
这个答案有帮助吗?
得分 0
添加一条评论
If it has been swapped into a different shell then it could be missing and antenna, if you were to open it and take a picture I maybe able to help.
这个答案有帮助吗?
得分 0
1条评论:
I've added a picture of the inside, though I don't think it shows much...
Thanks.
完成的
添加一条评论
Hello, I am having the same issue on an Iphone 7, anybody knows how to restore Bluetooth? (WiFi is ok)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mike Wynne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 204
