跳转到主内容
MacBook家族于2006年5月发布,替换了iBook来作为苹果消费级笔记本的产品线。
3787 个问题 查看全部
Screen Discoloration, color distortion, help deciding what to replace
I want to know if I need to replace the whole LCD or if I can replace an Inverter or a different display component or possibly do some cleaning. I have some photos of the broken mac next to a fully functional mac as well as some pics of the back side of the screen. I know that I probably need to replace the LCD but I am trying to stay cheap. This mac is a MacBook 2,1 2.16 GHz
It is definitely not a display setting, I have tried all of those and the screen is distorted even at the initial boot up.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
3条评论
What does it do if you hook it up to an external monitor?
完成的
How Do I Fix my MacBook Air with Discolor to the Screen? I can't see my FaceTime. Help?
完成的
Hi, I seem to have the same discoluration problem on my macbook MacBook (Retina, 12-inch, Early 2016). I'm not good with tech and taking things apart. my macbook is only maybe 3 years old and in brilliant condition. Never spilled anything on it ever and look after it pretty well. What can I do or who can I take it to? Im in Florianopolis BRazil at the moment.... thank you!
完成的
添加一条评论
2个答案
已选择的解决方案
There's corrosion on your LCD electronic board, on the LVDS connector/socket and also signs of electric shorts (black spots). I guess liquid was spilled in this area. You can begin by cleaning the corrosion with isopropyl alcohol and a small brush but IMHO the LCD will have to be replaced. Let us know if the cleaning job was enough to restore a normal video. Good luck.
这个答案有帮助吗?
得分 5
3条评论:
Thank you for the great idea. I used a little rubbing alcohol on some q-tips to clean the dirty spots and the display is as good as new. I saved $100 instead of buying a new LCD.
完成的
Hey, that's good news Shawn. It seems that the black spots were not signs of electric shorts and only the corrosion altered the video signal. Great !! Thanks for accepting my answer (-:
完成的
+ Nice answer lemerise - Those black spots are/were shorts. _______________+ Shawn GREAT presentation of your problem. I wish everyone posting their problem here would put that kind of effort into it.
完成的
添加一条评论
This could be caused by a few different problems, that you should try ruling out. First, try connecting it to an external monitor. If it works normally, then you have a problem with the LCD panel/LVDS cable. If it still displays abnormally, then you have a logic board problem. (More specifically, a problem with the integrated graphics chip) The only way to repair this is to reflow the GPU, or replace the logic board all together.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shawn 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 22
总计 19,395
