跳转到主内容
A single-serve blender made by Hamilton Beach in 2011. Similar to the Hamilton Beach 55103, 51126, 51131, 51132, and 51133.
9 个问题 查看全部
Blade doesn’t rotate
Hi,
I bought This Hamilton beach single serve blender from Walmart (Forgot to check at store while buying) and sent to Another country.
The motor running fine, the blade isn’t rotating when the Jar attached but the motor is running.
Please help me to fix it …
It’s brand new, didn’t work from day1. Can’t return it being outside USA now.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Review this guide Hamilton Beach 51101BA Blades Replacement See if the part of the blade assembly that connects to the base is secured to the blade within the glass vessel. also check to see if the you start the motor the block on the top of the base that grabs the blade assembly is turning. Take a pencil to see if the block is not lose when you start the motor use care as you don’t want the pencil to fly off! Just press it lightly along the wall of the block.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Lucky Francais 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 57
总计 2,373
