跳转到主内容
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
Why is the start button not working
so there are no errors and all the panel lights work. i checked the door switch and it is engaging as well. my question is, does the start button go bad and do i need to replace the display unit on the front of the machine or the ccu.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Cause 1
User Control and Display Board
To determine if the user control and display board is defective, try pressing the buttons on the control panel. If some of the buttons work, but others do not work, the control and display board might need to be replaced. Additionally, if the display is not working, check the power to the user control and display board. If the user control and display board has power, but it isn’t working, replace it.
Cause 2
Timer
The timer is frequently misdiagnosed—before replacing the timer, first check all of the more commonly defective parts. To determine if the timer is defective, consult your washer’s wiring diagram and use a multimeter to test the timer for continuity.
Cause 3
Line Fuse
The line fuse blows if the washer circuits are overloaded. If the line fuse blows, the washer won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. Check for shorted out components such as the wires, motor, or drain pump. If you don’t resolve the underlying issue, the new fuse will blow too.
这个答案有帮助吗?
得分 3
5条评论:
In simple terms, all buttons display but start button won't activate. Would this still be fuse? If fuse, wouldn't display not work or does it have separate fuse?
完成的
@goose4 Please unplug it for five minutes to allow it to reset and then tell us if you get any error codes or other responses.
完成的
Earlier first thing i did few times hoping for reset . Same results all display selections work and light up but start button does not activate. Also removed top of machine all looks intact. Did unplug power connection to control board and back in, no change. Is it fuse?
完成的
I'm having the same issue Randy did you get it sloved?
完成的
I have a question if someone could answer. I have a Kenmore 100 and it doesnt have a pull start button. You press it. None of my cycle lights are on. I have unplugged the washer and tried to run a diagnostic test on it after I plugged it back up. I cant get it to do anything. Can anyone help me?
完成的
添加一条评论
I have the same/similar issue except the wash button activates after holding on for a long time. With each passing month, the time held increases. All other lights-buttons perform fine. The door latch seems fine.
这个答案有帮助吗?
得分 2
8条评论:
Hi Jay -- did you ever get this fixed. I am experiencing the same issue
完成的
Hi Jay & Michelle, I’m having same problem. Did ya get yours to work? It’s so annoying to hold start button sometimes works but mostly have to keep trying
完成的
Yes I did. I believe what happens if the button over presses the switch bending the plastic housing. The plastic housing has become very brittle so I replaced the entire piece. Now I tell my family just lightly touch the button to start. No need to lean into it for pressure.
The fix was fast and simple.
完成的
I am going thru same with a Kenmore 100 I have to push start 2 or 3 times if I push hard it works but after you do that it turns right back on??
完成的
What is the part number for the piece you replaced? I found several and Sears site says it's discontinued.
完成的
显示更多的3条评论
添加一条评论
Mine does the same thing. I took apart the control board and switched the foam button piece with a button that I don't use, and it works every time. I've had to do this 3 times in the past 3 years, so I won't be buying Kenmore again.
这个答案有帮助吗?
得分 1
5条评论:
Did you only switch the foam top part of the button?
完成的
This worked for me. The start switch wouldn't activate but everything else did. The repairman told me I needed a new display board. I told him I'd think about it. After he left I switched out the Energy Saver foam pad with the Start Button pad and it works great. I cannot find anywhere to by the pads. Anyone find them online?
完成的
I'm having the same problem right now, the power button has worn off and I need to replace it, but I know where to buy the replacement sponge foam.
完成的
Where do you buy the foam
完成的
I would like to know where to purchase the pad. I got this washer secondhand (for free). The previous owner says the unit was working before it left the house. I'm able to select the temperature, wash cycle, etc., but the start button doesn't work. I've done a factory reset twice. Now I have *two* washers that don't work. :-(
完成的
添加一条评论
添加你的答案
Randy B Gossage 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 72
总计 18,354
