iPhone 6S plus no power after battery replacement
Hi, I changed battery on my iphone 6S plus and after this the phone can´t boot. When I plug DCPS to the phone it hangs on 0.20 mah. I have tried replacing Tristar but this didn´t fix the issue. Any ideas ?
thanks
Edit: This phone was bought “for spare parts”, because it didn´t turn on. Previous owner changed the battery because he had to charge phone twice a day. He didn´t remove display so there is no long screw damage. After replacing tristar the draw after prompting to boot is everywhere from 0,05 to 0.40 mah. There are no power rails from PMIC present apart from pp1v8_always.
It is recognised by iTunes.
I´m still learning so that´s why I buy broken phones trying to fix them. This one is headache.
Measurements taken from board ( no display/body ) around PMIC and main rails:
WHAT / WHERE / VOLTS / DIODE
PP_BATT_VCC / TP02 / 1,22 / 1287
PP_VCC_MAIN / C2120 / 1,23 / 1286
PP5V0_USB / C2310 / 0 / OL
PP_CPU / C2000 / 0 / 025
PP_GPU / C2011 / 0 / 025
PP_SOC / C2022 / 0 / 021
PP_FIXED / C0750 / 0 / 067
PP1V8_SDRAM / C2132 / 0 / 252
PP1V1_SDRAM / C2130 / 0 / 225
PP_CPU_SRAM / C2070 / 0 / 076
PP_GPU_SRAM / C2080 / 0 / 183
PP1V1 / C1243 / 0 / 247
Does low Volts on the main power rails means there is a short on the smaller rails ?
4条评论
You have too many variables going on in this phone in order to troubleshoot. When was the phone last working? What made you think it needed a new battery? What happened to the phone? What is the physical exam? Present a case like a physician.
由 jessabethany 完成的
@jessabethany Edit: This phone was bought “for spare parts”, because it didn´t turn on. Previous owner changed the battery because he had to charge phone twice a day. He didn´t remove display so there is no long screw damage. After replacing tristar the draw after prompting to boot is everywhere from 0,05 to 0.40 mah. There are no power rails from PMIC present apart from pp1v8_always.
There is no physical damage to the board or phone itself.
由 Michal 完成的
Did you check if the phone is in DFU mode ..?
由 Minho 完成的
@refectio I´ve connected this to itunes. Tried to update, got error 14, changed USB port, applied restore and update. Now it´s all set up but still, no image at all. this is weird
由 Michal 完成的
