跳转到主内容
加入维修社区 - 创建账户
Other than the Tahoe Limited Edition, the vehicle was redesigned for the 2000 model year on the new GMT800 platform, still shared with the full-sized pickups and SUV's.
brake pedal falls to floor
I have a 2003 Yukon denali. I have replaced front hub assemblies on both sides. both front calipers, hoses, rotors and pads. and also drivers side rear caliper. also replaced master cylinder. manually and electronically bled the brake system 10 or more times. if stitting at a traffic light after about 10 seconds the brake pedal falls to the floor slowly and the truck starts moving forward. what can cause  this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I changed brakes rotors and calipers brakes still not working
完成的
添加一条评论
1个答案
已选择的解决方案
A “soft” brake pedal that goes all the way to the floor can be caused by a number of reasons.
  1. Low brake fluid – check for leaks underneath the car. ...
  2. Bad brake booster – this can cause longer stopping time. ...
  3. Failing master cylinder – this is usually the culprit if you're not losing brakefluid.
  4. https://www.youtube.com/watch?v=DzS4VOJw...
这个答案有帮助吗?
得分 5
2条评论:
I agree with [ Mayer ]
I know this is an old post, but just in case anyone looks at it.
Always check for leaks first. You must check brake fluid level is not dropping. Only Then look for the other things like the Failing master cylinder, (internal seal failure). In my case I already replaced the master brake cylinder, so think I have a faulty ABS module itself ( faulty valves ), intermittently causing the pedal to go to the floor. It can also be caused by sticking calliper's. If a brake pad is moving away from the disk, then the pedal must travel further before the brakes go on. Also check your hand brake adjustment is correct.
完成的
Thanks just starting to have this problem
完成的
添加一条评论
添加你的答案
lisa walker 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 77
总计 12,157
