跳转到主内容
Google Pixel 2是谷歌第二代的旗舰手机,于2017年10月17日发布。这款手机的配备是5英寸AMOLED显示屏,64或128 GB的存储选项。它有三种颜色可选:黑色,白色,蓝色。
70 个问题 查看全部
Dropped Phone in Water
I dropped my pixel 2 in water and it was fine in the beginning. No short outs or issues. Plugged it in the charge when I went to bed. I woke up at 4 am and it wasn’t working. It still vibrates and my alarm went off, but the screen would not come on. I am also able to answer calls. Touch screen and sound work. I just do not think the screen can come on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Water damage can cause all kinds of problems, some of which may not be fixable without a board replacement.
Assuming your device doesn’t have permanent damage, the important thing is to try and get all the water out of the phone. If you haven’t already done so, turn the phone off and put it in a bag of rice (or silica gel packets, if you have them) for a day or two. This should help to draw any moisture out of the phone. Simply leaving it out in the air or trying to shake out the water will not generally work to remove all of the moisture, and it doesn’t take very much to short out a circuit trace.
This may not be enough to get everything working, but it should definitely be one of the first things you try whenever you have a water-damaged electronic device.
You should seriously consider having a repair shop look at it, even if it starts working after it is dried out. Corrosion on the circuits is progressive and will eventually kill the board if it is not properly cleaned and the damage repaired.
这个答案有帮助吗?
得分 0
添加一条评论
It would be better if your phone is open witch you can do谷歌 Pixel 2 屏幕组件维修更换指南 you don’t have to open it fully just a little bit is good. Don’t use rice it will get lost in your phone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Crowell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 1,392
