跳转到主内容
Will not reinstall OS from disks
I am attempting to reinstall the OS from the CD's and I get an error message saying there were errors. I have used these disks to run the hardware tests, view and repair harddrive, view and repair permissions. The computer will start up but then give me the black screen saying to restart. The disk would NOT verify before re- install but yet would run all the diagnostics. I then tried another OSx install disc which loaded the new OS, but then crashed while on the welcome screen. Is this a harddrive problem of a logic board or something else. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论
the ibook came with 10.4.2. I tried those disks plus I had 10.4 disks from my old tower. It seemed to install but then crashed at the welcome screen. Logic board??
完成的
Why do want to reinstall ? Did you have a problem before with the iBook ?
完成的
Yes, upon startup I get the black screen that says I need to restart. Can't get past welcome.
完成的
添加一条评论
2个答案
已选择的解决方案
Contact Apple and request replacement disks. If they still offer them they should be $15 plus shipping: http://support.apple.com/kb/HE57
这个答案有帮助吗?
得分 2
1条评论:
The gray disks from another machine usually will not work. They are machine type specific.
完成的
添加一条评论
Was the version of the OS that you installed at least the same or newer then the version that originally came with your iBook?
According to this guide http://support.apple.com/kb/HT2191?viewl... you need at least an OSX10.3
The crashing uppon loading the welcome screen does not sound like a hardware problem to me.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
michael 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 655
