跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
708 个问题 查看全部
How do you remove screws that are stuck but not stripped?
I’m trying to self-replace the joycon rail on the left joycon, and have run into a problem. The phillips-head screw on the rail is stuck on really hard, and will not spin no matter how hard I try pushing with my screwdriver. The screw is not stripped. How do I get the screw out without damaging the electronic parts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Using a larger diameter bit holder-handle will give you more torque to help move it. Make sure the bit is the correct one that fits all the way into the screw head. There new several types of handles, some have holes in the handle (fourth down) that will allow you to insert another small driver to add torque (essentially turning the driver into a turnkey.
What are you currently using?
UPDATE
It’s really hard to do repair jobs with the proper tools. iFixit offers a couple of very good kits for the beginners and of course fine kits for the advanced. Here’s a couple you might consider:
[关联产品丢失或禁用: IF145-435-2]
[关联产品丢失或禁用: IF145-436-2]
Here are the other available kits:
https://www.ifixit.com/Store/Tools/Toolk...
这个答案有帮助吗?
得分 2
2条评论:
J00 screw bit appears to have the best fit for these screws. I ended up stripping the joycon screws due to using PH00 instead.
完成的
I'm currently using a tiny one used for eyeglasses and such. I don't know the model.
完成的
添加一条评论
添加你的答案
SawaYoshi 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 42
总计 7,660
