跳转到主内容
三星新旗舰的大号版本,盖乐世S8+。发布于2017年4月。
167 个问题 查看全部
How can I prevent back glass from cracking more?
I have a customer that has brought me a S8 Plus, and they are wanting the charging port replaced. When they brought it to me me, the bottom left corner of the back glass is showing minor signs of cracking. I was wondering if it is possible to open the device without cracking it even further, or will the back have to be replaced all together?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I suggest using a suction cup towards the top of the phone, and try to get a plastic card underneath the adhesive for the rear glass.
Using an iOpener or a heating pad, gently move the card along, being very gentle towards the broken corner. So as not to stress any more cracks.
With any luck, the adhesive will hold the glass in place, and there won’t be any further damage.
Hope this helps! Best of luck with the repair.
这个答案有帮助吗?
得分 1
2条评论:
I would certainly advise the customer that it may crack if worked on.
完成的
I already explained that there would be risks involved with the repair.
完成的
添加一条评论
Matt had some great suggestions. First, I always advise my customer that there is a risk of breaking the glass more when it’s cracked like this. First thing is to heat the back up really good to loosen the adhesive. Then I would suggest starting at the top. Normally I start at the bottom but I want to avoid the crack. Keep the back really hot and take you time. The card was a good idea. Ether way, I wouldn’t have high hope for getting this back glass off in one piece. Of course, in person I could see the crack a lot better.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Elijah Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 822
