跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
Screen Glitches after back glass shatter.
I dropped my Iphone X resulting in the back glass getting shattered.
After I shattered the backside the front screen started clicking things in a spesific part of the screen by itself. Bottom/mid right side.
No Visual glitches or damage can be seen on the front screen.
Has anyone encountered the same problem and have a fix?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I would suspect that the screen was damaged by the impact that shattered the rear glass. At this point, the only way to know for certain is to try a replacement screen. Considering the cost of a replacement screen, you could always drop by a repair shop to see if they can try one of theirs.
这个答案有帮助吗?
得分 3
2条评论:
I was at a local repair, they looked at it without even opening it. And told me a repair would be $700 usd. Which I'm honestly not gonna pay to repair my secondary phone's screen. If switching screens is the only thing needed to get it back working, would you recommend doing it at home and ordering a screen online, or is the process too complicated?
完成的
It's not that much different than any other recent iPhone ... except that mistakes cost more money now ;>). OLED replacement screens are still quite pricey. You can get an LCD replacement screen for less but the screen quality will not be on par with an OLED.
Check out this guide and see if you're comfortable.
完成的
添加一条评论
Like Minho said. The impact likely damaged the screen as well. New screens are not cheap however $700 is way to expensive to fix the phone. Some repair shops are charging closer to $400 so do some looking around and see if you can get a better price. Unfortunately due to how new the phone is, parts are still expensive and you have to think, repair shops will also charge for labor as well.
The repair is quite simple as only one component need to be transferred to the new screen however if you damage the part in any way, Face ID will no longer work. If you don’t feel confident with doing the repair yourself then take it to a repair shop. I would just make sure to check what there policy is if they damage the phone.
这个答案有帮助吗?
得分 0
1条评论:
One other thing it could be is that the frame got bent. If that's the case it could be putting pressure on parts of the screen causing the same result. If your frame is bent it might be as simple as just bending the frame back. Likely however, it's the screen itself.
完成的
添加一条评论
添加你的答案
william.s.johansen 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 37
总计 5,291
