跳转到主内容
A1418 / EMC 2833 / Late 2015 / 3.1 GHz Core i5 or 3.3GHz Core i7 Processor. Released October 13, 2015.
Possible to replace glue with magnets?
Older iMacs had magnets to keep the screen in place. Wouldn’t it be possible add magnets to the newer iMacs which have the screen glued on? So that when you have to open your iMac the first time, you do not glue it back together but glue in some magnets and some metal and simply snap the screen back in place?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Nope, there’s no room. The earlier iMacs has room for a metal plate all around the display and room for magnetic pins. This one does not have the room nor thickness to alter it.
这个答案有帮助吗?
得分 3
2条评论:
I would love Apple to go back to the magnets. Sadly as @mayer stated just not possible.
完成的
Too bad. I hoped for the newer, modern neodym magnets.
完成的
添加一条评论
What about magnetic tape?
https://www.amazon.com/Flexible-Magnetic...
I have not tried this myself but I will probably try it next time I have to open up one of these iMacs. Although honestly, I try very hard to not bother. The main thing people want is a larger/faster hard drive and it’s better to use an external (in most cases an SSD) rather than going through the hassle of messing with cutting then replying adhesive.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Skeeve 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 849
