跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Front Camera and ear speaker not working after battery replacement
Hi all!
I recently replaced the battery on two iPhones, a 6s and a 6s Plus and had a lot of fun. Everything seemed to work, however after some time i realised the front camera and the ear speaker of the 6s Plus are not working.
The display is turning dark when the phone is placed next to the head during a call, so I assume the light sensor works (?).
Answers to many similar questions posted to this forum suggest that the flex cable connecting the logic board and the camera might be torn.
While I was super careful, didn’t bend the screen over 90 degrees and can’t spot any damages on the cable, the connector or the logic board (I also removed the screen before removing the battery), i’d like to replace this cable.
I noticed that the flex cable is not available separately in the iFixit store for the 6s Plus. Its only possible to purchase a whole new screen which includes the cable.
Is it possible to replace this cable on an iPhone 6s Plus without replacing the screen? And would eg. this cable be the right part? It doesn’t mention the ear speaker.
https://www.ebay.de/itm/Fur-iPhone-6S-Pl...
Thanks for reading. Best regards,
Felix
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Here is the link for the ear speaker.
Here is the link for the Front Camera / Sensor Flex.
A damaged Ear Speaker is pretty rare so your issue is most likely caused by a damaged FCAM flex or incorrect installation/alignment.
iPhone 6s Plus Earpiece Speaker图片
产品
$19.99
iPhone 6s Plus Front Camera and Sensor Cable图片
产品
$29.99
这个答案有帮助吗?
得分 2
添加一条评论
You may just have to replace the entire screen. I found an iFixit link below, that notes that replacing the speaker is separate. Unfortunately, I don’t know where to find another earpiece, so just go with a new display. (iPhone 6s 前置摄像头与光线传感器组件更换)
Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Felix 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 4,505
