跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
iPhone Proximity Sensor Testing
Hello All, my question is based around the “Voice Memos” application I normally used to test the proximity sensor on iPhones. Normally, I would record something for at least 10 seconds, play it back with the loud speaker off (so I would hear it like it was a normal call), then by simply covering the proximity sensor the LCD would go dim. Then when removing my finger from covering the sensor the LCD would light up again. Recently I noticed when going into the Voice Memos that the speaker option was not there, just an edit link.
Actual Question: How can I test the proximity sensor on the iPhone now a days in 2019, without making a call?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hold home button to open Siri then cover sensor with hand and screen should turn off.
这个答案有帮助吗?
得分 4
1条评论:
Awesome, thank you Mtwo!
完成的
添加一条评论
Personally, I don’t think there is anything wrong with making a quick call to test the proximity sensor. Not only can you test the proximity sensor, you can also check the earpiece and loudspeaker at the same time. You also get the added benefit of testing the cellular antennas. We just communicate with our customers what we are doing.
这个答案有帮助吗?
得分 2
2条评论:
That only works if the customer left their SIM card within the device.
完成的
We are testing in bulk, so to make a call is not very efficient for what we are trying to accomplish. But thanks for the feedback!
完成的
添加一条评论
If you record a voice memo and cover it up (whilst still recording) it still works with new ios.
这个答案有帮助吗?
得分 1
2条评论:
...and it plays back on both the loudspeaker and ear speaker in "stereo". I use it to test all three functions.
完成的
Thanks for the feedback! Haven't tried this method, but will keep it in mind.
完成的
添加一条评论
添加你的答案
-DC 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 33
总计 735
