跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
I dropped my iPhone 7 and both cameras and flashlight stopped working
I dropped my iPhone and suddenly the both cameras (rear and frontal) and the flashlight stopped working. What it could be? Does it have a fix or its better to replace the phone with a new one?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The rear camera is the key here. The front camera and flash will not work if the rear camera is damaged and cannot be enabled. So the simple thing to try is replacing the rear camera with a known-good replacement part (or from a quality vendor) to see if that solves your problem. If it doesn’t, then you may gave a logic board issue. Repairing a camera issue at the board level is relatively straightforward and much less expensive than replacing the device.
这个答案有帮助吗?
得分 3
1条评论:
Thanks! I'll try this one
完成的
添加一条评论
It’s probably a board level repair. You could try and replace the cameras but it probably won’t do much. You could also try and do a full reset and then it might start working again.
这个答案有帮助吗?
得分 1
2条评论:
Thank you! I'm doing a full reset right now. If it don't work, do you think i need to replace the entire logic board? Is it worth it?
完成的
At that rate I would just upgrade to a new phone because the iPhone 7 has so many other problems like the audio ic boot loop problem etc.
完成的
添加一条评论
添加你的答案
Eduardo Wichoski 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 839
