跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
iPhone 7 rear camera and flash not working
my iPhone 7 hard dropped from running bike ,
then after i got below issues
1) wont turn on ( Power IC replaced - Working fine)
2) audio prblem ( Audio IC replaced- only headphones not working charging works fine)
3) screen totally damaged ( new screen replaced)
4) Rear camera and flash not working ( after replaced U2501 ic also not working & also checked with another camera not works ) showing only black screen
i fixed all issues except rear camera , even after replaced U2501 ( CAMERA IC ) Problem was not fixed front camera working fine
kindly suggest me best solution to get my camera back to works again
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Could be main board damage (smc was knocked off by drop or something along those lines) or the connector on the main board was damaged or if you're frame is bent or damaged it could be shorting out.
完成的
I’m guessing it’s CPU Issue
And compute benchmark score value is zero
完成的
Well it's probably main board not CPU. If it was CPU the odds of it booting is so low. Probably time for a new phone.
完成的
You are right but I spent more than $200 for this minor repairs
That’s the reason I can’t go for another phone
If I got solution this issue will fix it nd sold
Kindly tell if any jumper option to get fixed this issue
完成的
添加一条评论
1个答案
已选择的解决方案
There are several power rails that power the Rear Camera, U2501 being only one of them. Check to insure that U2501 is properly powered by VDD_BOOST and then check the other rails in the image below.
这个答案有帮助吗?
得分 2
3条评论:
Any jumper solution can work on that
Like remove U2501 IC and put jumper between A1 & A2 will work?
完成的
"Jumper solutions" are not solutions. You need to invest some time to understand what U2501 is (hint...it's an LDO) and what it does (hint...it takes VDD_BOOST and regulates it down to 2.9V).
If you jumper the input and the output of U2501, what happens?
完成的
Okay, thank you
I had small clarification kindly mention in detail
Is this rear camera unit connected to A10 cpu
Because previously I reballed
完成的
添加一条评论
添加你的答案
feroz_khan77874 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 967
