跳转到主内容
加入维修社区 - 创建账户
MacBook Pro Early 2011 won't turn on.
So I have a Early 2011 Macbook Pro 13’ that won’t turn on.
Basically, when I press the power button, the usual chime that tells you the machine is starting doesn’t go off and the only thing that I can hear working is the spinning hard drive?
So I’ve opened the bottom case and confirmed that the fan doesn’t spin and the only thing that seems to be being powered is the hard drive.
The light on my Magsafe charger when plugged in is a solid green, the button I press on the side to check battery power has all the lights on green, so I don’t think it’s an issue of the battery not being charged.
I’ve tried a solution I read where you unplug the battery, hold the power button for 10 seconds and then plug it all back in. That was a no go.
So basically I’ve come to the conclusion that maybe it’s the logic/mother board that’s faulty?
Basically I’m here for confirmation on whether or not my deduction is right, any possible troubleshooting I can do and where to go from here?
Thanks for the help in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Dead systems are always tricky to diagnose!
While the battery may appear good, given the systems age I’m sure it’s getting close to needing to be replaced.
Did you have a liquid spill at some point? Over time a spill can erupt into a bigger problem on the logic board.
I would make the effort taking it out and make a full inspection looking for any damage. Take the time to dust the board and the internal areas using a soft paint brush to scrub the surfaces and a can of can’ed air. MacBook Pro 13" Unibody Early 2011 Logic Board Replacement
If you see anything take a clear sharp picture of the area and post it here fo us to see 在已经存在的问题里加入图片
MacBook Pro 13" Unibody Early 2011 Logic Board图片
指南
难度:
困难
20 - 35 minutes
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Juan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 107
