跳转到主内容
The Samsung Galaxy Grand Neo was released in February 2014. It is a mid-range smartphone with a 5.01-inch display and a variant with dual SIM. The GT-I9060I model is known as the Samsung Galaxy Grand Neo Plus.
46 个问题 查看全部
update installs up 96% and it just writes error
i have a galaxy grand neo plus. i tried installing a system update, the update installs up 96% and it just writes error and reboots and jams at the same stage of installation. what should i do. im stranded
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @ndothi
You should try following solutions:
  • Remove SD Card - if it’s installed - press volume down and power button for over 10second - your device will be restarted - Then you can try install update again
If the problem still ocures:
  • Restart your device to the recover mode and wipe cache partition of device - Then try update again
If still ocures:
  • Turn back your device using Factory reset
You can also try to install update in safe mode.
Regards
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ndothi Sikota 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 65
