跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Flash ROM apparently dead.
Hi all. I am looking at buying an iPhone 6 plus privately. It was upgraded to iOS 12 at which point the seller is saying the flash ROM has died/crashed and the phone now won't boot fully into IOS. Questions are:
1) is this common?
2) is there a fix and if so, is it complicated.
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
yes there may be a fix... does the seller tell you it is jailbroken? does he get an error code? Sometimes stuck in boot loop is an easy fix, sometimes it's a brick. Ask for the error code and then we can give more accurate answer
完成的
添加一条评论
1个答案
已选择的解决方案
Are you referring to an iPhone 6 Plus or an iPhone 6S Plus? Your question and product selection don’t match.
There is no Flash ROM in an iPhone. There is an EEPROM, and SDRAM and a NAND IC. If your seller can give you more precise information, then we can help you better. That said, none of these issues are trivial in nature and unless you have micro-soldering skills, I wouldn’t bother with this device. There are plenty of quality pre-owned devices out there, you don’t want to be saddled with a phone that has logic board issues such as this.
这个答案有帮助吗?
得分 1
1条评论:
iPhone 6s plus as per the thread title.
完成的
添加一条评论
添加你的答案
Simon Palmer 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 5
总计 240
