From whee I can buy the back panel for galaxy s10 plus?
i want to buy the back panel for galaxy s10 plus cuz i broke mine .
and onther q . if i replace it . is the water resistant will go away ?
As far as I know, there aren’t currently any replacement glass casings on the market. It’s a very new phone! You’ll just have to be patient for suppliers to get some stock, and maybe consider a case…
It most likely won’t be water resistant after a replacement, but if it’s cracked it definitely isn’t water resistant anymore anyways.
这个答案有帮助吗?
ubreakifix seems like they have parts in stock. Not something you can do yourself but if you need it fixed, definitely an option.
You can replace the back glass yourself, but remember, heat is your best friend! totally not something that jerryrigerverything said ;p
We have guides for the procedure! Follow this guide: 三星Galaxy S10+ 更换后盖
Mobile Defenders has the back glass.
It will become less water resistant depending on the type of adhesive and type of way you seal up the back.
这个答案有帮助吗?
you can buy a LUVSS back glass from amazon with camera lens and full set tools kit.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 1,992
