跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for sinks, taps and faucets in your kitchen or bathroom.
Faucet handle won't come off to repair leak
Plumber ended up just scratching finish in attempt to remove handle! Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Do you have a specific model, brand, or anything? There's not enough information here.
完成的
添加一条评论
2个答案
已选择的解决方案
Hire a REAL plumber!!!! or…
If you get the brand, model number, etc. it is easy to look up on the web.
You can even find repair kits. We fixed our Metheven kitchen mixer tap for about $15.
All that was needed was a Philips screw driver.
这个答案有帮助吗?
得分 1
添加一条评论
It the cover has no flats so as to accommodate an adjustable wrench, then try a rubber strap wrench. If the cover is made of thin metal over plastic as many are today, then be careful not apply too much force because the fulcrum of the strap wrench may dent or crease the thin metal.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jessie MCKillop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 379
