跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
Fan won't stop running
I easily replaced my broken exhaust fan. (the old one had two small broken plastic pieces causing the fan to still work but it rattled).
The new fan now spins ALL the time, regardless of the laptop temperature. It starts spinning at 2000 rpm as soon at it turns on. From a dead cold position. This causes a low annoying hum. I tried resetting both the SMC and PRAM but the problem persists.
Any ideas?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Fan speed at 1900/2000rpm is the absolute minimum speed with your Mac model, there’s nothing unusual with that, when the Pc is hot it ramps up to 6000rpm. If it’s particularly noisy at 2000rpm, unless you have a specially low tolerance to noise, you might have received a faulty fan.
这个答案有帮助吗?
得分 1
1条评论:
It's a brand new fan but I'll check it out. Thanks
完成的
添加一条评论
最有帮助的答案
A lot of times with the fans it could be your SMC or PRAM that needs to be reset. These parameters can sometimes go a bit wonky and cause all sorts of system issues, however I see that you have already attempted this. Where did you source the fan from? The laptop fans are typically controlled via software with readings from a thermal sensor, however if the fan does not have the exact wiring that the previous did, it will instead run full speed as there’s nothing controlling the voltage to it.
这个答案有帮助吗?
得分 2
添加一条评论
Try looking for any runaway applications That could be potentially using too much CPU.
If you don’t see a problem there, iCloud’s Documents and Data and Photos syncing can cause the Mac’s CPU to overheat and can cause the fan to run continuously even if the applications are running anything requiring a lot of CPU. By disabling those two services, you may be able to set the fan back into standby
这个答案有帮助吗?
得分 1
1条评论:
Thanks Gary but the activity monitor says nothing is pulling more than 7.7% cpu and that's the activity monitor. I have no iCloud document, data or photo syncing; only contacts and notes. The internal temps are all below 100F yet the fan is running at 2,000 rpm and makes an annoying humming noise. I don't think this is normal and I don't know how to fix it since I already reset the SMC and PRAM. Any further suggestions?
完成的
添加一条评论
添加你的答案
Steve Paskay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 557
