跳转到主内容
Preparing Automatic Repair with no loading symbol
I am on a iBuyPower, and I didn't put that in the device because there was no iBuyPower option, but it is stuck on Preparing Automatic Repair, with no loading, spinning, thing. I've waited around 20 mins, any help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
What is an "iBuyPower"? Any one know?
完成的
Hi @aactech ,
Perhaps it is a custom built or self built desktop with parts sourced from here
Cheers.
完成的
Hi jayeff,
O.K that makes sense now.
完成的
Just so you all know, I have finished fixing my computer, without deleting countless of personal files.
完成的
What did you do to fix
完成的
显示更多的1条评论
添加一条评论
2个答案
已选择的解决方案
From your Comment is see you tried “Startup Repair'“. I would try this one at least three times. Some times the repair can take several steps before it works.
If it still does not fix the “Startup” then I suggest doing the “Reset this PC”
If From “Automatic Repair” select “Advanced options”
From “Choose an option” select “Troubleshoot”.
From “Troubleshoot” selcet “Reset this PC”
Once in “Reset this PC” remember to select the option to keep your files and reset Windows.
This will reinstall Windows 10 keeping your files.
这个答案有帮助吗?
得分 2
1条评论:
Thank you, but I am glad to say that I was eventually able to fix the computer. Also, an IBuyPower is a computer making company (according to google) Sorry if I wasted your time, but apparently, after a couple days of waiting for the Attempting Repairs, it finally fixed itself, somehow. Sorry if I wasted your time, just forgot to delete the question.
完成的
添加一条评论
Reinstall windows if you have the software
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eaglegrant 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 2,479
