跳转到主内容
Model M7572 / 400 or 500 MHz G3 processor
Why is my keyboard not responding?
The following keys: 2, w, s, x, keys all quit working after I dripped Iced Tea on a portion of the keyboard. I removed the keyboard, wiped the back off with a soft cloth, re-installed the keyboard but it did not help. I did not see any moisture on the front of back side of the keyboard.
Is there an option to clean the Pismo keyboard, or does it have to be replaced?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Hook up an external keyboard and see if it works. If it does you will need to replace your onboard keyboard.
这个答案有帮助吗?
得分 3
2条评论:
Thanks Mayer. I did as You recommended. I now have the new onboard keyboard in operation.
完成的
Glad I could help solve your problem and keep this classic running.
完成的
添加一条评论
添加你的答案
hlstory 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 836
