跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
OS install, can't access partition in disk utility
I replaced the HD in my '98 macbook penryn model, then I accidentally loaded a Leopard upgrade DVD instead of the grey install disk to re-install my OS. I followed the instructions for formatting the drive in disk utility with the wrong disk, then when I tried to install realized my mistake.
Now I am using the right disk but the computer doesn't recognize the HD as a location to instal, and I can't access the partitions tab in disk utility to check formatting/re-format. I get the message "disk utility has lost connection with disk management tool and cannot continue. Please quit and relaunch. The partition scheme is now listed as "master boot record"
I have tried restarting holding down 'alt' and also 'c' with no results.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Try starting from the Leopard upgrade disk, "C" key. Try the partition with it and do the GUID partition.
这个答案有帮助吗?
得分 1
6条评论:
Everthing looks good with the upgrade disk: GUID is set, and there is 1 partition that I named Mac HD. But now what? I can't install from here, "mac os x cannot be upgraded to v10.5 on your computer. mac os x v10.4 or later could not be found on your computer" Thanks!
完成的
Now go back to your original installation disk, if it's the one for this machine, and install your system. Next use the upgrade disk to upgrade it.
完成的
What is the best way to switch the disks? I can't eject using the eject key; the only way I was able to switch the disks so far was ejecting by holding the mouse key with start up... And then loading the original, do I need to hold anything down during start-up? This switching disks business is how I got stuck with my original problem in the first place...
(and I do have the original install disks)
完成的
Hold the mouse button on startup to eject.
完成的
Then hold "c" again for start up with install disk?
完成的
显示更多的1条评论
添加一条评论
If you are not able to access volume in your Mac, you must use some third party tool, which works effectively. I am using Stellar Partition Manager tool to create, format, delete, resize my Mac volume, it is very easy to use and reliable. I am sure if you could use this tool you will definitely format/re-format your Mac volume.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Muse 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 2,920
