跳转到主内容
型号A1040 / 10, 15, 20, 30, 或 40 GB 硬盘/ 中央转盘上方有四个触控激活 LED 背光按键
Battery Replaced, Recognized by Computer, Won't Charge?
I just replaced the battery with an iFixit (super easy!) and the iPod started right up. It is showing little to no battery power. When I connect it to by Macbook, iTunes recognizes it, but it does not charge. I’ve tried multiple chargers with the 30-pin cable (brand new) and I can’t get the lightning bolt to come up.
The only suggestions I’ve seen are related to replacing the battery, which is what I just did. I went back, disconnected the (new) battery and reinstalled it, still the same issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
It’s FireWire…isn’t it? I’m not using FireWire to charge…
完成的
To clarify, when you said, "The only suggestions I’ve seen are related to replacing the battery, which is what I just did. I went back, disconnected the (new) battery and reinstalled it, still the same issue." does this mean that you disconnected and reconnected the NEW battery, or you disconnected the new battery and reconnected the OLD battery? I'm curious to see if the iPod will charge on the old battery.
完成的
添加一条评论
2个答案
最有帮助的答案
Your problem is the connection. The iPod 3rd Gen does not charge through USB but needs Firewire connection. This model only syncs through USB. Hope this helps, good luck.
这个答案有帮助吗?
得分 3
添加一条评论
You need a FireWire cable and power adapter to charge it.
Cable: https://www.ebay.com/sch/i.html?_from=R4...
Power adapter: https://www.ebay.com/sch/i.html?_from=R4...
Note: Some eBay listings already include both things in them, since they are used together.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ryan Harris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 114
