跳转到主内容
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
Display lcd not working
The display does not light up but itunes detects the ipad. I disconnected the battery and it seemed to work, but after some use it is no longer accessible (itunes, however, detects it). Some advice? Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like maybe the LCD flex cable is coming loose. I’ve actually seen a guy smack the opposite side of an iPad 2 and correct a loose cable. Not sure if the 4 flex would react the same. It is a different connector altogether. You may try putting it on its right side vertically, then bump it down into your palm or lightly onto something kind of soft like rubber. Then soft reset. Hopefully your LCD isn’t going out and this helps. Otherwise you gotta open it up to investigate.
这个答案有帮助吗?
得分 0
1条评论:
It does not seem to be the flexible LCD cable. I opened it when I unplug and hang up the battery seems to turn on but only up to the apple. I do not know if the problem is the LCD or the battery.
完成的
添加一条评论
添加你的答案
Cristiano Zotti 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 79
