跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 个问题 查看全部
New battery says "Service" after just 4-5 months
Hey.
I have some problems with a mid 1466 macbook air and battery.
I replaced it with a brand new one, but allready after a few months it starts saying “battery needs service”.
Does it need a recalibration or SMC reset?
Anyone else have experienced this?
Best
Update (03/21/2019)
Hi Dan. Thanks for the answer, i got a hold on the macbook now. Here is picture with adaptor plugged in. Right now, if I remove power the macbook LCD goes black.
picture of coconut
Update (03/21/2019)
I have replaced battery and reset SMC. Shift ctrl alt power for 10 sec. Charger goes from orange to green to orange, as it should to confirm the reset.
Right now the Mac battery % and Coconut does not seem to agree the current charge in %
coconut after battery replacement
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Install this gem of an app CoconutBattery take a snapshot of apps window with the MagSafe plugged in and a second with it disconnected, post both here for us to see 在已经存在的问题里加入图片
完成的
I wouldn't worry about the discrepancy. The OS value is just updated faster than what CoconutBattery is able to.
Other than that is the system stable?
完成的
添加一条评论
1个答案
Try recalibrating the battery. It probably is thinking it’s the old battery, even though you replaced it, so a recalibration should help. If not, try removing the battery, powering on the MacBook, shut down (safely!), and reinstall battery.
Good luck!
这个答案有帮助吗?
得分 0
2条评论:
Thanks for answer. :)
Callibration = charge to 100% and leave plugged in for 2-3 hours more. drain battery and leave for 5 hours min. then charge full again?
Best
完成的
添加一条评论
添加你的答案
Anders Laursen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 218
