MacBook will not run on battery
Hi,
My MacBook is running Snow Leopard will not start up on battery, after 3 secs and some optical drive noise it shuts off. With charger attached it keeps cycling trying over and over to boot.
When I removed battery and reset SMC holding the power switch with battery and AC disconnected it will start on the MagSafe. This is a new battery I have struggled to fully charge and discharge twice but still if it does start on battery is shuts down after a few mins of operation.
I had this attached to a FireWire audio interface and external monitor and stupidly left charger always connected. I have reset SMC, PRAM, out of Ideas
Any help thanks
Update (03/04/2019)
Hi thanks for reply. Between shutdowns these are screen shots from the app:
Lets get a better idea on the batteries health install this gem of an App CoconutBattery take a snapshot and post it here for us to see 在已经存在的问题里加入图片
由 Dan 完成的
@a1mac - Martin the battery looks like a newer battery. Lets give the diagnostics a try do you still have the grey installation CD's. One will be labeled diagnostics. using it to boot up your system see what it tells you.
由 Dan 完成的
Hi Dan I purchased this secondhand and do not have the CDs.
由 Martin 完成的
Not good, Can you contact the seller to get them? Otherwise you'll need to find someone local who can diagnose the issue.
There's a good chance the logic board has a problem. Maybe it would be smarter returning it and getting your money back so you can get a better system,
由 Dan 完成的
Hi Dan I purchased this in 2014 secondhand. Can I download diagnostic from online or I have usb stick (OSX 10.6 installer) for my mac Pro tower. Other then that I will have to chance changing Logic board which I am capable of doing.
由 Martin 完成的
显示更多的2条评论
