跳转到主内容
Repair guides and support for top and front loading Whirlpool brand washers.
425 个问题 查看全部
How to fix Whirlpool top load washer out of ballance problem
Whirlpool /Maytag washer model MTW5840TW0 works great, except on the drain and spin cycle. The drum starts to spin and the water drains. Once all the water has drained the drum goes out of balance and hits the cabinet. What could be the problem? I’m thinking its the suspension springs, but just by visual inspection they are not broken or rusty.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
This question was migrated from https://meta.ifixit.com/Answers.
完成的
添加一条评论
2个答案
已选择的解决方案
There about 12 causes for this but it is usually a bearing. Here’s the list along with replacement parts:
https://www.repairclinic.com/RepairHelp/...
这个答案有帮助吗?
得分 2
添加一条评论
I have a whirlpool WTW7500GC2 washer that suddenly started vibrating more than usual. I have taken the top off all the suspension springs are intact and do not look damaged. I have purchased them, and will replace them anyway. Is there anything else it could be
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Phillp Saxton 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 30
过去 30 天: 93
总计 9,213
