跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2265 个问题 查看全部
I need to turn off cellular data for unresponsive screen on airplane?
I cracked my iPhone screen 2 weeks ago, but I don’t know how. I picked it up from on top of my backpack and it was shattered. The screen worked “perfectly fine.” However, last week, my screen began to not work for periods of time. I’d wait a minute, and it would work, only for it to shut off again a few minutes later. The display worked perfectly and Siri worked, but the screen could not detect my touch. I went on a flight so I told Siri to set it to airplane mode (not a good idea). Now I can’t turn airplane mode off. I can’t tell Siri to turn my cellular off either. I’ve tried holding down the power and the home button to power it off but it won’t. I’ve plugged it up to my iTunes, but it asks my phone if I trust the device, and I can’t state that I trust the device because my screen is broken. I have a back up phone to use… I just need to turn off cellular data on this iPhone. PLEASE HELP!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hello,
To do a force restart on an iPhone 7 and above, you need to hold the power and volume down buttons, as the home button is now a touch sensor (no more “real” button under this guy, the Taptic Engine inside your phone makes you feel it clicks but it actually doesn’t).
There is no solution to toggle on the “trust computer” box though. Try to find a broken but working screen and mount it yourself, then toggle it. Otherwise, you can always try to ask a nice repairing shop to do that for you.
这个答案有帮助吗?
得分 2
1条评论:
Thank you!! Everywhere I had looked said home button and power button, but as you know, that didn’t work. I finally had found a video yesterday telling me to press volume and power like you said and after doing that twice, my phone is working now! Thank you! Also, I will be taking it to the shop to get it fixed this week. I just needed some type of cell phone for the time being!
完成的
添加一条评论
How about just getting the screen replaced.
Edit: It would really drive me nuts trying to use a phone like that.
这个答案有帮助吗?
得分 1
2条评论:
That’s the expensive but right solution yeah.
完成的
I’m actually getting it repaired later this week, but I just needed a phone for the time being! My car broke down earlier and I didn’t have a phone to reach anyone in case you wanted some context.
完成的
添加一条评论
so how did you fix it, im having the same problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Reese 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 1,911
