跳转到主内容
iMac 21.5"(Intel)維修指南及客户支持
Reboot loop with mojave Patch tool
I’ve got a mid 2010 21.5” iMac. I installed Mojave with the patch tool provided by Dosdude1.
Since then my iMac keeps rebooting over and over again. And I could not do an Internet recovery mode for some reason so I took out the SSD, cloned it from another Mac and reinstalled it. Still the same problem. Did a PRAM reset and this came up (see pic)
Problem not solved.
Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Did it flash the EFI chip (firmware update)? What version did you use?
完成的
Of the patch tool? 1.2.3, SHA1:57cd15435e42ad8928ae3ff8f5a45033a0ed1d9e (the latest one)
完成的
添加一条评论
1个答案
最有帮助的答案
I ran into the same issue and was not able to remedy it unfortunately.
这个答案有帮助吗?
得分 1
4条评论:
Yeah, guess I got greedy. Should have stuck with high sierra...
完成的
you're not greedy, you're ASPIRATIONAL
完成的
SOLVED! So, finially I cloned the old harddrive from another iMac (with El capitain)since I was thinking that maybe it had to do with the missing OWC (the lose fancable), maybe with the OS system itself. I also changed the memory from 16 (4x4) to the original 8 gb. And it worked. And after a bit of troubleshooting I realized the problem was the internal memory. Don´t know if there was something wrong with them or what but now the iMac is running. Will try to change the HHD to an SSD and keep the old memory because now it should work. YEAH!
完成的
Thanks for sharing! Can't wait to try it
完成的
添加一条评论
添加你的答案
holger eriksson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 543
