跳转到主内容
The Kenmore Model Number 970-678431 is an inductive cook-top range with single door oven and warming-drawer.
16 个问题 查看全部
Dimmed Frigidaire stove electronic display
( right model Frigidaire BFEF374A )
I bought this used stove and the digits on the digital display are barely visible. I sought a solution and found that cleaning contacts or changing the capacitors might solve the issue. Contacts of the display are welded in the unit’s board but I changed the capacitors and it is still the same.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Possibly a cold solder joint on the control board. Reflow it it with a cheap soldering iron.
That failing, replace it.
这个答案有帮助吗?
得分 1
1条评论:
Thanks Mayer, I will revisit this option. I admit I did not check if all the solder joints were still intact.
完成的
添加一条评论
添加你的答案
Bob Harris 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 268
