Backlight stops working, intermittent. What can I do?
I have the MacBook Pro 13 RETINA A1502 2015
and the motherboard is at bottom.
Laptop works fine, then after a while, the screen goes out. I an see the screen if light is shown through the apple etc, so there is content, but no light. Then I open the back cover and press on the corner in upper right area where you see the display connection and also undo that clip and put back. Then the laptop works again for few days. Then light goes out. Is there some small part I can replace? or something I can do on that motherboard? I don't see any rusty areas or loose connections, it all looks fine but I assume a loose connection somewhere. Trying to solve without having to get new logic board.
Thanks for your help
