跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Screen won't close tight after display replacement
I replaced new display for iPhone 7 by LCD Screen and Digitizer Full Assembly Fix Kit and I have no problem during repairing steps where I applied new display adhesive.
Now I have problem when I close device that is a gap between the display and rear case, exactly on bottom right corne and on half bottom of right side.
What do yo suggest me ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
已选择的解决方案
I found out problem! It’s problem with new display, I tried to assembly again the old display and It closes tight.
There is IC cent to display flat and It’s not aligned, infact bump into metal shield of rear case.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Hi
Perhaps your phone frame is bent, because of this skew the screen does not sit tight to the frame
这个答案有帮助吗?
得分 1
添加一条评论
I have the same problem for mine, and I think it might be that the battery bracket may be pushing up on the screen. My battery bracket was popping up on one side while the other was screwed down and I had trouble screwing both of the the tiny screws in without one popping out. This causes the entire battery bracket to sit at and upward angle and apply pressure on to my screen. This may not be your exact problem but it is worth a try to see if that could be it.
这个答案有帮助吗?
得分 0
添加一条评论
it will be the small rectangular heatshield on the back of the new screen not alignet correctly, there is a recess on the loud speaker it has to sit in.
这个答案有帮助吗?
得分 0
1条评论:
strange thing is the old lcd sits down correctly, what do you think? It's design flaw?
完成的
添加一条评论
I tried everything on mine and it ended up being that the back was slightly bent. I bent it back into shape gently and resolved the issue.
这个答案有帮助吗?
得分 0
1条评论:
omg i had the exact problem and thank you i wouldnt think the frame would be bent now i know the actual reason
完成的
添加一条评论
添加你的答案
Riccardo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 8
总计 2,006
