跳转到主内容
加入维修社区 - 创建账户
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
Unit will not fully boot.
I’ve tested multiple hardrives with known working partitions.
i’ve swapped out the hardrive cable with a new functional cable.
tested the hardrive on separate macs, and they work fine.
I’ve performed a Pram reset and reset the SMC to no avail.
It passed multiple extended hardware tests.
It has no peripherals connected and isolated further by removing the non essential components, Airport/diskbay.
And i legitamitly have ran out of ideas.
any thoughts are welcome…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
does it work with a USB to SATA adapter?
完成的
It will not boot to externals or recovery mode.
完成的
添加一条评论
1个答案
Is it shutting off at 75% loading bar? Usually it's bad GPU in the 2011 15” unibodys.
这个答案有帮助吗?
得分 0
1条评论:
It’s making it to 100 percent but then it just hits a blank white/gray screen and shuts off and try’s again.
完成的
添加一条评论
添加你的答案
Jared Owens 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 62
