跳转到主内容
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 个问题 查看全部
Where can I find the 12+16 SSD logic board connector?
I’m helping a friend revive a MBP Pro 2014 from an accidental spill after sternly admonishing him for being a menace to his MacBook Pro while drinking his juice. Luckily, his data is safe, but several pins on the nameless, proprietary 12+16 SSD connector on the logic board are charred for life. I’m planning on replacing it with a new connector.
I’ve read the connector referred to as "gumstick" on the board schematics. I have conducted extensive searches, but I can't find it listed anywhere as a replacement part. I find it surprising given how easy it is to find other connectors and it's vulnerable location for liquid damage. I did find it on a few PCIe adapters, but the profile doesn't provide enough clearance for the bottom cover.
Any ideas where I should look?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I found the connector, though not as a discrete part. It turns out the Mac Mini 2014 has a flex cable featuring the 12-16 connector on one of its end:
From the photo, you can see the connector cleverly disguised with some black electrical wrap covering the metal shield plate.
这个答案有帮助吗?
得分 3
2条评论:
Not a bad idea! Let us know if it worked.
完成的
Works like a champ! Now I have a working MBP machine. Take that Steve Apple!
完成的
添加一条评论
You probably won’t find it anywhere new, I’ve never seen it for sale..you’ll have to buy a donor board to find one.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
AppleGuyPie 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 11
总计 441
