跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
What tools do I need to use when replacing thermal paste?
Using the MacBook Pro 15" Retina Display Mid 2015 Heat Sink Replacement guide, what tools must I acquire to replace the thermal paste on the CPU?
I don’t have any tools, but the store here have tools. I just don't know which ones covers the issue.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
What kit should I acquire, please?
完成的
添加一条评论
1个答案
已选择的解决方案
Hello,
Check this guide out for a list of tools.
Basicly, you’re going to need a P5 Pentalobe screwdriver, a T5 Torx screwdriver, a spudger, your thermal paste, and a cloth to wipe off the old paste. That list is also at the top of the guide you mentioned. right under the introduction. There are also easy “add to cart” buttons for each mentioned tool. If you’d like, you can also just get the ifixit Pro Tech Toolkit. It comes with many tools and all kinds of bits to get the most stubborn and special screws out.
Good luck fixing/replacing the thermal paste!
Maxim
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Henrik Spang Poulsen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 694
