跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 个问题 查看全部
No Sound From Internal Speakers. No Output Devices found
Basically one day my mac no longer had sound coming from the speakers.
It will however play sound from bluetooth and also usb speakers seem to work.
Headphone Jack also does not work.
Ive tried literally everything I can find on the internet and nothing is working. I’m beginning to think its an actual hardware issue. But im not sure what I need to replace.
I’m fairly comfortable taking my macbook apart, and at this point just need to know what part to get to fix it.
I’ve read its the :
I/O Board Power Audio Board
Can anyone confirm?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If headphone jack doesn’t work either, it’s quite likely you have a logic board issue. Unfortunatly there’s nothing you can replace on that Macbook model, the A1286 has no I/O board at all, everything part of the audio circuitry is firmly soldered to the logic board. A component level repair would be required to get things back working.
这个答案有帮助吗?
得分 2
1条评论:
Yep, time for someone to fix your logic board or a new one. Likely the DAC logic has an issue.
完成的
添加一条评论
添加你的答案
Dj Neff 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 135
