跳转到主内容
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 个问题 查看全部
Why is my iMac not working?
Hi,
I always put my iMac on sleep when i am not using it once a time when the iMac was on sleep I heard a strange noise like (zeeee,zeeee,zeeee,zzzzz) it's like it want to run or do something and it can't the after half Minutes shows a question mark inside a file
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sounds like your hard drive has failed. Start up from your system installation disk by inserting the disk and starting holding down the "c" key. Go to the second screen pull down menu to Utilities > Disk Utility, and see if you can select the hard drive on the left. If so repair the drive till it runs clear. If not let us know, also if it is still under warranty.
这个答案有帮助吗?
得分 3
7条评论:
I tried this one the iMac start and eject the CD by it self
About the warranty yes it's under the warranty
完成的
Don't touch it. Get the warranty service. It sounds like something besides the hard drive may have failed. I'd also consider getting AppleCare if you don't have it.
完成的
But I can't send the whole iMac to AppleCare because i am not in the U.S right now. I can take with me the hard drive . What else may inturrpted and you prefer to take it with me to them
完成的
Where are you?
完成的
I am in Saudi Arabia I called apple they said we don't have AppleCare here in Saudi Arabia although we have some company said we are dealr of apple.
I'm going to U.S this summer I can take any thing has normal size with me to AppleCare
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Faisal 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,001
