跳转到主内容
这是一系列帮助修理洗衣机的指南和支持。
Why won't my washer fill for rinse cycle?
Washer fills for wash cycle. Drains & spins normally. However when it's time to fill for the rinse, I only hear clicks. Washer is an LG inverter direct drive top loader.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
I have this problem too- soap suds overflowing from machine - use only very small amount of soap powder (same as always in past).!!!
完成的
I have this problem as well. My machine is a Frigidaire top loading.
完成的
@zobedahose99656
What is the model number of your washing machine?
完成的
添加一条评论
3个答案
已选择的解决方案
If the washer drains after washing but will not fill in the rinse cycle then checking the pressure switch would be a good idea. If the tub is empty you can remove the plastic hose, give the switch a thump and reattach the hose. Does it fill now?
If not then you can remove the violet wire and tan wire from the pressure switch and join them together with a small piece of insulated wire.
Remember to unplug the washer first before attempting this.
With these two wires connected the washer will fill if the pressure switch is the problem.
According to your specific model number the color of the wires may differ.
这个答案有帮助吗?
得分 2
3条评论:
The new standard today for all top load washers do not allow for a "clean water" rinse. The washers wash the load, then drain and spin ending the cycle. There is no rinse cycle anymore even though the word "rinse" is illuminated! I find this extremely disappointing because there is going to be detergent still left in the load at the end of the cycle!
完成的
I have same problem. I think this is unsanitary as soap and or bleach are not removed. I run a second load without soap. It's amazing how much gray water is in the wash cycle.
完成的
Same here & I've also run a wash cycle without soap to ensure enough water is in the tub to actually perform a rinse function. grrr
完成的
添加一条评论
You may have a bad timer and need to replace it. The timer controls every cycle that the washer does. I’m sure that the manufacture will ship you one if you can provide the model number/serial number. I hope this helps. Bluesman01
这个答案有帮助吗?
得分 0
添加一条评论
Is there a way to bypass the new water saver washing machines. I hate my whirlpool washer because only a set of queen sheets come out with dry areas that never got wet. I make sure I push down to make load even and still dry areas. I’ve tried using bulky cycle with high water level just to get a small load clean! I’m tired of clothes not getting clean as well! How does washing clothes twice save any water?
这个答案有帮助吗?
得分 0
1条评论:
Hi @jennieanndisher
What is the model number of your washer?
完成的
添加一条评论
添加你的答案
amandamead81 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 78
过去 30 天: 308
总计 9,856
