I cloned new SSD, installed, works for 2 hours then screen goes black
My problem is this:
I Installed a new SSD into my mid 2009 MacBook Pro.
At first it was working great, then after watching some video's, screen went black, after the cursor just spun and spun. sometimes after going black I'd be able to move the cursor sometimes not. after a force shutdown, and restart, then I'd get the circle with the line, or the question mark.
I put back the old drive, worked perfectly. it was suggested to change the hard drive cable, which I did, and surprised how easy it was, booted up the computer, all excited, and after using after a couple hours watching video from same site (mypoints.com) the same thing happened! So i reinstalled old drive, and booted up the new drive from an enclosure, but not a 3.0 (not sure if that matters) and it worked flawlessly the rest of the day...
Now I have the old drive in, and I'll know if it works like is used to, as I'm sure it will...
I really don't want to have to just keep the external attached to use.
Please help... I'm also thinking about bringing it in. I even bought a folding laptop stand with fans in case it was getting to hot, and it happened again …
4条评论
What is the make and model of the SSD you put in?
由 Dan 完成的
Did you copy the original drive to the new one?
由 Caliber 完成的
Caliber - Eric Cloned the drive which is a copy of the original drive.
I personally don't use cloning apps any more as they are passé. They often create more problems than their worth. I only use the built-in Migration Assistant tool it never fails!
But thats not the issue here, there is something hardware wise thats amiss.
由 Dan 完成的
i tried to use the migration assistant, but it just searched, and searched for the drive and couldn't find it... so originally i just cloned the drive, and when it happened, i used time machine, and it happened again... still happening...
由 eric k 完成的
