跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2265 个问题 查看全部
iPhone 7 nand didn’t extract any information
I have removed band memory chip on iPhone 7(I have done it multiple times, as I repair phones)
nand drive shows successfully on the programmer but when I extract it there was no information came up( strange) no body has removed nand from this phone before
question.
1 what could be the reason that no address or serial number is extracted from nand
can an I get those all addresses from anywhere by imei or the phone is bricked?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
@tomchai Do you have any idea?
完成的
I don’t know what was wrong at the first place. No water damage no short at all. Tristar wasn’t short either. No body touched the phone before apart from restoring it with iTunes.
but there must be a way of getting all the addresses by imei or…..
完成的
添加一条评论
3个答案
最有帮助的答案
Was there something wrong with the phone originally?
E.g liquid damage, VCC_Main short, bad battery along with tristar fault?
Any of these can cause short circuits to the NAND making it corrupt / fried and not fixable. Phone is probably bricked if you can’t extract the SN / Wi-Fi mac info from it.
这个答案有帮助吗?
得分 2
1条评论:
完成的
添加一条评论
Hi all helpers,
i found the solution as WiFi address and Bluetooth address are more important than all of the rest information(as new phones have so many serial numbers)
so so I found a service I can retrieve the Bluetooth address and WiFi address from the serial number and imei number.
so for your information if it happens there is a solution for it.
这个答案有帮助吗?
得分 2
3条评论:
Why not share with the community where you found this information. That's the whole point of this forum. It's one thing to ask for help, it's much better when you share the resolution so that everyone benefits.
完成的
https://anycodeunlock.com/product/iphone...
You have to pay for this service
You must have serial number of the phone or imei number. I ll share you the full video once it’s ready.
完成的
Is this service still available ? I have SN value and I need BM and WM.
完成的
添加一条评论
If the removed memory chip didn’t provide anything, I don’t think there is any backup for baseband data anywhere else.
这个答案有帮助吗?
得分 1
1条评论:
never seen any data lose in nand memory chip . Do you know what could be the reason for no data in the nand
完成的
添加一条评论
添加你的答案
Soft Solutions 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 666
