跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
224 个问题 查看全部
How to replace WIFI antena? Paste it? what about cables?
Hi,
In this picture its the iPhone 2g without the LCD:
http://img217.imageshack.us/img217/1135/...
Which of the white cable(1, 2 or 3 in the pic) is responsible for the WIFI signal?
How can I know if the problem is the cable, or the whole ANTENNA Module (the red square in picture)?
the phone/network carrier signal is OK, its just the WIFI which bad.
And if I buy this Antenna module:
http://img861.imageshack.us/img861/817/4...
How the I replace it?
I should paste it?
Is it difficult to install it?
thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The white cable is an assembly of 2 cables with total 4 connectors - you need to replace as an assembly if you think it is faulty
See HERE and zoom the picture
This GUIDE should assist in replacing the Antenna module - specifically from step 21.
The module is likely held in with double sided tape. Something like THIS may be suitable for re installation.
这个答案有帮助吗?
得分 0
3条评论:
Wow.. Thanks for nice answer:)
I have a friend that his WIFI doesn't work.
So I thought to open his iPhone, and try 3 things. Please tell me what you think:#see if the white antenna cable connected in their places. #replacing the Antenna module with Antenna module from an old iPhone. #buying a new Antenna module or white Antenna cables if nothing will work.
Another questions:=*Where is the Antenna that makes the calling signal? I mean the 3G and not the WIFI? I want to know the risk of "playing" with Antenna module part.. if I can make more damage that it was before?
Thanks
完成的
By the way - i found out, that the wifi cable is only one of the cables that attached to the Antenna module, what makes me think that it is a big risky to replace the ANTENNA module because I can loos the ability to make calls - 2g/3g/gprs signal. here u see where the wifi is in the buttom,:
http://img191.imageshack.us/img191/5317/...
完成的
Shai if I remember correctly the cables are pop on/ off no glue required. Like iPhone 3G connector for wifi or 3GS connector 7.... So be careful and you'll be fine. The glue is a low temp silica type that they put on at manufacture/assembly to keep everything in place. You don't really need to replace it
完成的
添加一条评论
添加你的答案
Shai 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,561
