跳转到主内容
SATA interface not working at 6Gb/s after SSD replacement Solved
I have a MacBook Pro early 2011. I replaced the original HD with the Samsung EVO 860 SSD 500GB.
I replaced the SATA cable (I read several posts about needing to do this) and I had no problems making the switch. However, I checked the system information and it says that while the SATA port is 6.0 Gb/s, the negotiated speed is 1.5Gb/s.
Since the port and the SSD are rated for 6.0Gb/s, should I assume that the cable is faulty even though I replaced it? I purchased the newer 2012 cable but not from iFixit (maybe cable quality is the issue?).
Also, I did not know about putting electrical tape on the inside of the case to protect the cable; I read about it in a post after I completed my installation. Is there another possibility for the negotiated speed being lower or do I need to purchase a new cable again and install with the electrical tape? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
What is your OS version?
Can you take a set of snapshots of the hardware system report showing the SATA/SATA Express section clicking on both of the Intel chipset sections 在已经存在的问题里加入图片
完成的
Hi Dan - Your question made me realize what I was doing wrong. I was looking at the DVD drive information which is operating at 1.5Gb/s. When I clicked on the SSD information it shows that it is communicating at 6Gb/s as expected.
I don't know if this behavior is related, but my wife noticed that when the laptop is plugged in it works great. However, when the AC adapter is not plugged in the laptop becomes sporadic and sluggish. The battery indicator shows that the battery is full (97%). I read some posts that said to reset the PRAM and SMC; I did that but it has not changed the laptop's behavior when it is unplugged. Any ideas? Thanks.
完成的
Hi Dan - Thanks for the guide on inserting images. I added the results from the app (adapter connected and no adapter connected) to the original question.
完成的
添加一条评论
1个答案
已选择的解决方案
Well, I’m happy to hear you’re getting the proper throughput from your SSD.
What your wife is clueing us in here, the battery likely need replacement.
Lets get a better view of things, install this gem of an app CoconutBattery take a snapshot of the main window and post it here for us to see 在已经存在的问题里加入图片 so we can see whats happening.
这个答案有帮助吗?
得分 1
8条评论:
Dan - Should I run the app with the AC adapter plugged in or out?
完成的
Take one each way
完成的
The battery look OK and the battery currently appears to be charged even though it presently doesn't show it is charging.
I think you'll need to run diagnostics to see whats happening here. Press and hold the D Key when you start the system up.
Reference: Mac startup key combinations
完成的
Dan - Should I run the diagnostics both ways (AC adapter plugged in and disconnected)?
完成的
No, you do't need to run it disconnected.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
oldsports 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 275
