What is the part to the right of the forward facing camera?
What is the part to the right when looking at to forward facing camera? It’s rectangular with a ribbon.
Cellular antenna and cable assembly. Your iPad isn't a wifi-only device. Well, at least, it wasn't before you cut it.
这个答案有帮助吗?
Not necessarily, it could still work in some circumstances.
Such as on some bands/networks
That would be probably a cellular antenna, but if you didn't see a Sim slot it is a Bluetooth antenna. If you think you damaged it, the I would suggest putting it together, and turning it on to see what it was. If it was something you used, then consider purchasing a replacement (if available).
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 55
You need to be more specific. Take pictures of it, give us more details, and is it on the inside or outside of the device? (I am assuming inside)
由 Timothy McEvoy 完成的
It is on the right Hand side internally. Facing the forward facing camera. It has a two pieces ribbon coming off of it. With a twin part with no ribbon on the left. I accidentally cut it.
由 grantlamoy1 完成的
So can still use WiFi but not cellular?
由 grantlamoy1 完成的
Yes. Cellular may still work, but you may get poor reception on certain bands.
由 Arthur Shi 完成的
