iPhone 6 plus boot loop
Hello while i was repairing my phone, the lcd shield with the homebutton cable ripped on me, do you think that because of the homebutton not working it could cause a bootloop ?
Leave the homebutton cable unplugged from the logic board and try starting your iPhone and you’ll have your aswer :) The iPhone should be working normally even without home button.
这个答案有帮助吗?
It still bootloops.
@a_f_yt_ Then unfortunately we got a different issue here. If your older screen is still functioning give a try with it to rule out a possible defective replacement screen. Have a close check of your connectors on the logic board too, possibly with a good light source and some magnification.
sometime when you don’t connect battery properly, it can be on boot loop.
Connect the battery and disconnect the charger and try it to turn on if it’s on bootloop than there is issue with the board.
if it wouldn’t show anything than plug the charger
if it’s only on bootloop while just connect the charger and the battery it means either your battery is not connected properly or it’s damaged.
because if you connect just the charger without battery it shows bootloop and the phone try to turn on but because battery is not giving it’s A that’s why it’s not turning on.
这个答案有帮助吗?
Before I attempted any repairs the phone would still turn on but the battery was inflated so I had to replace the battery because the old battery was inflated and wouldnt tske charge.
have you tested the way I ask you?
if it’s new battery already than you need the battery activaterto activate the battery. If you don’t have a battery activater. Than you can activate it with power supply.
Hey Angel,
If you’re sure the cable ripped, that’s almost definitely why the phone is in a boot loop. Just like a computer: if it’s missing a critical component, like RAM, you’ll get an error code or a beed code and it will fail to boot up. Especially considering the home button, with the fingerprint scanner, is so critical to the security of your phone.
Since you’re probably not an experienced technician, I wouldn’t advise that you attempt to repair the phone any further. Take it to a TRUSTED local repair shop or find a repair shop here on iFixit. Be transparent with the technician and let them know what happened. From there, they should be able to remedy the situation and get your iPhone 6 back in business. Otherwise, you’ll have to take it to your local Apple Store or send it in for repair.
Hope this helps!
-Alex
这个答案有帮助吗?
I knew about the iphone boot test and if it's missing a part it wont bootup. Before I attempted any repairs the phone would still work but I had to replace the battery because the oldbattery wouldn't take charge anymore. And yes the phone still bootloops with new battery. But I bet it was the homebutton cable for sure.
I havent damaged the phone in any sort of way, the phone bootlooped eith the old battery before I attempted repairs.
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 159
